SHANLING A10T LETTORE HDCD CD CON USCITA VALVOLARE
atropo73
Messaggio da atropo73 »
Come da titolo vendo il sopracitato lettore cd / hdcd con uscita valvolare SHANLING A10T, da me regolarmente usato tutt'ora ed in mio possesso da circa 3 anni.
Queste le caratteristiche tecniche:
The unit is a hybrid CD player with Philips-servo-system CDM-12C/D7-II and 24bit/96kHz D/A converter Burr-Brown PCM1732 with HDCD decoder*). Its output stage is designed in Class A circuitry. Amplification is taken over by tube OPA2604 I/V, responsible for the warm, soft, but, also precise expression of sound.
The player components are mounted in a stable full aluminum enclosure with massive brushed aluminum front panel and good ventilation system. Material dimensions and quality level are outstanding and on a level you might find only with very few other brands.
Design is simple and cool, handling-optimized, excluding unnecessary toys and extravagances, perhaps, just in this way nice.
Selection of material, dimensioning, treatment as well as manufacturing are of absolute perfection similar as for design and outfit.
Handling and operating are functional and easy as well.
CD HDCD Player. Philips CDM-12 laser head drive. Philips Servo Circuity. Burr-Brown PCM1732 HDCD/CD DAC, plays both CD and HDCD encoded CD. Employs high quality power transformer and audio grade components. All aluminum casing.
Specification
System: HDCD*), 24 bit / 96 kHz
Rated output voltage: 0-2,5V, adjustable
Frequency range: 20Hz-20kHz±1 dB
S/N: >110dB
Distortion: <0,002% (1 KHz)
Dynamic Range: >110dB
Channel separation: >96dB
Outputs: Analog L+R, digital co-axial, 24k-gold-plated
Power supply: A/C 220±10% Volt / 50Hz
Power consumption: max. 80 W
Environment temperature: 0 - 40°C
Dimensions: 430x82x370 mm
Weight: 10 kg
Colour: Aluminum - silver
Remote control: IR, massive aluminum
Prezzo richiesto 400 euro compresa spedizione con pacco celere 3 assicurato (viste le poste italiane non sì sa mai!!!!)
agli interessati posso inviare foto dettagliate.
Per qualsiasi altra informazione aggiuntiva non esitate a contattarmi;
grazie della cortese attenzione, :grin:
Gianluca.
ATTENZIONE : vendita tra privati.
FORMULA DI ESCLUSIONE DELLA GARANZIA: L’ attuale legislazione prevede anche per i privati la fornitura di garanzia sugli oggetti venduti, a meno che non sia esplicitamente esclusa al momento della vendita.
Pertanto, l'oggetto proposto è venduto "così com'è", con esclusione esplicita di qualsiasi forma di garanzia, salvo la garanzia del perfetto funzionamento dell’oggetto e della corretta descrizione dello stesso.
atropo73
Re: SHANLING A10T LETTORE HDCD CD CON USCITA VALVOLARE
Giusto per precisazione, il lettore è in vendita anche su altri circuiti e per equiparare le tariffe scendo come ultima proposta a 350 euro più spese di spedizione.
Grazie della cortese attenzione,
