MARANTZ DV8300 / DV 8300SACD DVD - A
Come da titolo vendo il sopracitato lettore dvd, dvd-A, sacd marantz dv 8300 finitura argento.
Tale modello è stato TOP di gamma 2003/04, con prezzo di listino 2490 euro.
Di seguito le caratteristiche tecniche del lettore:
MARANTZ DV8300 Player
Multichannel/Surround
• THX Ultra / Select -/•
• Decoders built in: DD / DTS / MPEG •/•/•
• Digital out (DD/DTS/MPEG) •
• VIRTUAL SURROUND •
Audio/Video enhancements
• Pal 60 Conversion •
• Progressive Scan (NTSC) •
• CD Compatibility: CD / CD-R / CD-RW / HDCD / SACD •/•/•/-/•
• VCD Compatibility: VCD 2.0 / SVCD •/-
• DVD Compatibility: DVD / DVD-R / DVD-RW (Video) /
DVD-RW (VR) / DVD AUDIO •/•/•/•/•
• MP3 PLAYBACK •
• Audio DAC Type for SACD: DSD / Multi-Bit •/-
• HDAM: metal / copper / gold -/•/-
• Video On/Off •
• Display On/Off •
• Dedicated High Grade Audio Power Supply •
• Audio Transformer: EI / Toroidal / Super Ring •/-/-
• High grade audio components •
• Customized Components •
• Chassis: Metal / Copper -/•
• Rear Panel: metal / copper -/•
• System Blocks Shielding: Metal / Copper •/-
Other
• Selectable Filters (SACD) •
• Display Dimmer •
• Auto Aspect Ratio
• Still Picture •
• Multi Language OSD •
• Multi Channel Down Mix: MPEG2 / DD / DTS / DVD AUDIO •/•/•/•
• Video Signal Control •
In/Outputs
Video Audio
Composite Out 2 Scart 2
S-Video Out 1 Analog Out (Cinch) 1
Component Out 1 5.1 Channel Out •
Scart (RGB) 2 Digital Coaxial Out 1
D-Bus In & Out • Digital Optical Out 1
OSD selection switch Gold Plated cinch •
(Auto / PAL / NTSC) •
Gold Plated cinch •
Specifications
Video DAC 108mHz /12-bit
Audio DAC 192kHz/24-bit,
front; 96kHz/24-bit centre + rear channels
Dig. Audio Freq. Response 2Hz-100kHz (SACD)
S/N Ratio 118 dB
Dynamic Range 108 dB
Total Harmonic Distortion 0.0013%
General
Color: Black / Gold •/•
Metal Front Panel •
Remote control RC8300DV
Power Consumption 18W
Detachable Power Cable •
Maximum dimensions (W x H x D) 440 x 89 x 307 mm
Weight 6.2 Kg
Prezzo richiesto 450 euro compresa spedizione con pacco celere 3 assicurato (viste le poste italiane non sì sa mai!!!!)
agli interessati posso inviare foto dettagliate.
Per qualsiasi altra informazione aggiuntiva non esitate a contattarmi;
grazie della cortese attenzione,
Gianluca.
ATTENZIONE : vendita tra privati.
FORMULA DI ESCLUSIONE DELLA GARANZIA: L’ attuale legislazione prevede anche per i privati la fornitura di garanzia sugli oggetti venduti, a meno che non sia esplicitamente esclusa al momento della vendita.
Pertanto, l'oggetto proposto è venduto "così com'è", con esclusione esplicita di qualsiasi forma di garanzia, salvo la garanzia del perfetto funzionamento dell’oggetto e della corretta descrizione dello stesso.
MARANTZ DV8300 / DV 8300 SACD DVD - A
